- Apr 27, 1999
There seems to be some confusion about how wire edges work. Usually a wire edge will cut paper well. It is very thin and has microserrations and this is good for cutting paper, but it will not stay sharp very long. If you can feel the uneven edge by strumming (I like that term by the way) you do have a burr, but you also have not removed enough material from the blade to get a full clean edge.
Color the sides of your edge with black felt pen. Using the flats of the stone do a few strokes to see where you are abrading the edge. I still think that you are not getting to all of it. Some of that "burr" may be leftover from a bad factory edge or previous blade damage. If you use the Sharpmaker by stroking alternate sides you should not feel an asymmetrical burr. You could create one using the edges of the hone and really high pressure, but I wouldn't expect it to be conspicuously asymmetrical unless you worked one side of the blade at a time. If you do a complete sharpening job with a Sharpmaker you will get a burr, but you should not be able to feel it. As you finish sharpening you use the flats and light strokes and that should mostly allign the burr with the middle of the edge.
General tips: Do NOT use the white rods until the very last few strokes if you are reworking a really dull edge. Use the edges of the grey rods for reprofiling then smooth your reprofiling using the flats of the grey rods. Do the felt pen test at this point to be sure you have worked your way up to the edge all along the blade. Ease up on your honing pressure and do a few more strokes to allign the burr. Don't do this by feel, you are doing this cause you know it is there. Now you are going to do some strokes with the spine of the blade tilted away from the rods (towards the center of the V between the rods). To remove the burr you have to hone lightly with your medium rods at about twice your normal honing angle. You are tilting the blade so that as you stroke the edge down the right rod the blade is nearly parallel to the left rod (and vice versa). You only do about 5 strokes per side, alternating sides. Now the burr you couldn't see is gone. This is really where you start following the Spyderco video. It assumes that you are not having to do major reprofiling. Work lightly on the flats of the grey, then the white rods. If you are working at the 20 degree angle and the edge does not get as sharp as you want, do a few very light strokes at 25 degrees by slightly tilting the blade spine away from the rods. Don't remove much or your edge will get obtuse, but this should give you a fine edge.
