- Nov 26, 2014
Hi all, got a M43 that is simply a beast and need to know exactly how the Edge aligning tool is "SAFELY" used ! Thanks !
(Now if I could only learn to keep a convex edge on flat stones, rolling the blade as I go and all that.)
That my friend makes for a beautiful blade. I can do it but it is a lot of work but sure is beautiful! Probably my favorite edge but the recurve of the Khukuri doesnt make it practical.
I find a 1inch dowel wrapped with 800 grit paper works the balls. The edges on kukris are very waves so a flat stone will only get the high spot. A dowel from cho to tip works best for me.
Do you place a soft backing between the sandpaper and dowel? The more I think about this system, the more it appeals to me.
Yes I either use an old thin rubber mouse pad or just wrap the tip with paper style masking tape. It only takes about ten rotations around the dowel to get a nice "soft" feel. Wrap the sandpaper around the masking tape. I find flat stones and even wooden stropping blocks far less effective than the dowel or mouse pad technique. A soft flat mouse pad will let the lateral bumps in the cutting edge hit the paper. Hard flat stones only sharpen the high spots
Excellent tips, thanks! One more question - when using the dowel, are you trying to replicate the pressure that the knife's weight would exercise over the mousepad, or are you going lighter?
I will deff. try and see if this, paired with a smaller vice, gets me a more consistent result.
