- Sep 10, 2010
I'm curious to see how you guys place the final edge on your knives and how I can improve my method.
Sorry I don't have a picture of my setup but I do all my final edges on my KMG. For hunting knives and slicers I try to get final edge thickness before sharpening down to .010. For tomahawks I tend to leave a final edge thickness of .025 but may go thicker or thinner depending on the design. I use my rotary platen at low speeds and freehand cut the final edge. I aim for about 15 degrees per side but there's obviously some slop since I'm not sharpening with a jig. For most knives I set my initial bevel with a sharp 220 and then finish with a fresh 320. I do all of my final edges wet with a sprayer directly on the edge to eliminate heat build up. Before I started using water I burnt a couple edges even with fresh belts and slow speeds
From there I usually go to the paper wheels and strop the edge.
With my method I tend to get good, sharp edges that cut well but I have some worries.
1.) Since I freehand my angles are not perfect and it bugs me, especially around the tip I tend to open up the edge too much. I'd like to see how guys with jigs sharpen.
2.) Though paper wheels leave a really sharp edge, I don't think edges done with paper wheels stay sharp as long as edges sharpened by hand. I've never done a direct comparison but I have my suspicions.
So how do you guys set your final edges?
