How Good (or Bad) is 440A?
Four-forty A is becoming an increasingly popular blade steel as steel imports become increasingly expensive. How good or bad is it in relation to other steels like AUS-8 and AUS 6? I know some folks don't like it at all. Even so, I have a Cold Steel Night Force that seems to be holding up fairly well. Also a CRKT Ryan 7 with teflon coating which hasn't seen much use.
Thanks.
I don't like it, but it's probably comparable to AUS6. It's not a great edge holder, IMO, but it's pretty well maintenance free, and very flexible as far as stainless steels go. You can get it verrrrrry sharp, though, assuming the edge isn't too thick. That's about all I know about it. I think the makers who use it do it because A) it's cheap, relatively speaking, and B)it can be stamped out, unlike, say 154CM, which has to be cut out.
Randall use's B. I think its a cheep steel though. And randalls are made to be looked at...
It's an easy steel to stamp out blades and machine. That's why factory companies tend to use it alot. It's ok for edge holding and doesn't rust easily.
Scott
It all depends on the heat treatment. If Paul Bos heat treated your 440A, you'd know it would perform quite well, and probably better than "superior" steels with inferior heat treatments. Look at what Buck is able to squeeze out of 420HC with Mr. Bos' heat treatment.
Cold Steel typically does a pretty good job with their heat treatments. Not so with some others who do a lot of 440A.
The hardening process that seems to work well involves the use of liquid nitrogen to quench the steel. The Chinese use...what's it called? Oh, yeah, water. Or, in the worst case, air. Cold Steel, Buck and other reputable knife makers all use liquid nitrogen.
The NO2 is used after the steel has already hardened in air or some other quenching medium, usually followed by an additional temper. Paul Bos is the only heat treater I know who uses NO2 treatment for *all* their heat treating. That's why I use him on my custom knives. He's the absolute best...if you see his name attached, you can just about guarantee it's superior steel (or at least heat-treated in a superior manner).
I agree. The choice of steel is imprtant, but the choice of heat treat is even more so. When someone does their own heat treat, then I am suspect unless it is simple carbon steel. Heat treating is not simple for alloy steels. 440A is a decent steel IMO. It is American made as opposed to AUS6A which is the Japanese version of 440A with a slight ingredient change.
I would rather have 440A heat treated by Paul Bos than S30V not heat treated by paul bos. Hows that.
There ain't no magic to heat treating steels. If you'd choose 440A over S30V just because Mr. Bos didn't heat treat the S30V, you might just be making a big mistake. Because S30V is a MUCH superior steel for knife blades than 440A. And any competent, professional heat treater can do a good job heat treating S30V. Just as good a job as Mr. Bos in fact.
If you'd said you'd prefer a properly heat treated 440A blade to a badly done S30V blade, then I would agree with you.
I do agree with you that I am also very suspect of those who heat treat their own stainless or highly alloyed blades. The amount of equipement needed to do a consistent, professional job on these steels involves a real serious investment of money. Like $100,000. You also have to know what the heck you're doing. This is one reason why I have all of my blades professionally heat treated by a large firm who know me and my quality standards. They also have the testing equipement to insure absolute quality control. Deep cooling between tempering cycles is widespread in the industry and has been for years. Not just in the USA.
The biggest difference between Mr. Bos and a lot of other heat treating outfits is his specializtion on knife blades, his years of experience and the fact that he tends to straighten the blades himself. This is a service almost no other heat treater offers and a giant plus for knifemakers. If I were in the US, I woud send my blades to him. However, a properly heat treated blade is a properly heat treated blade. No magic involved. Anyone can do it who has the experience, the will and the equipment. Mr. Bos does and he is certainly a master of his craft, but he ain't alone in that regard.
The key is knowing who is doing the work for you and being sure of their abilities.
Also, 440A is a US designation for steel (as AUS6 is a Japanese designation). Neither of these designations say anything about where the steel was made. The steel industry is totally globalized. I recall a while back when a well known US Maker had quality issues with O1 toolsteel from Starret. After a lot of back and forth with Starret (which the Maker made public), Starret told him that O1 isn't made at all in the USA and that they buy their steel on the world market according to supply and demand. They have no way of knowing if the steel they sell today is made in Korea or Spain or where ever. They buy tons of it, mark it Starret and sell it off.
Kevin, I agree. What I meant was that I would trust 440A done by Paul Bos (or other quality heat treater) than S30V done by a Knifemaker/backyard treater.
Paul Bos is just so well known that it is easy to mention. There are good Heat Treaters all over, I am sure. But like you said the investment in equipment is huge for this process. How many knifecompanys advertise who does their heat treat for them? Not many.. Buyer Beware. That is one huge advantage to going Custom. You can ask who did the heat treat.
Almost sounds like Randall.
I sure agree with you then: if Mr. Bos does the heat treating, both Maker and Buyer can rest easy that the steel has been properly done.
I'm also leary of "mystery" or "super special nobody uses my magic formula" heat treating BS whether from Makers or factories.
I send most of my carbon steel blades to Markus Balbach because I know him and he is one of the best Smiths in the business.
My HSS and stainless steels go to a very professional heat treater here in Berlin. The ovens they use cost 6 figures and their employees are highly trained and experienced.
BTW, the Maker I was referring to wasn't Randall.
Kevin, I agree with your take on mystery HT's to a point. For example when Mile Stewart says he has his own proprietary HT on A2 and is not willing to give it up (which I understand) I have no problem with it because I am fully aware of the high performance his product displays. His HT is indeed excellent, regardless of where it is beng done. But you have to know the Mfg or Maker to make that assesment or you have to test the product to verify.
I used Mike as an example, but that would be true for many Mfg's/Custom Makers. They may not want to give up their HT so you either trust or you don't. Eventually the truth of quality will get out, whether good or bad.
HTing is not rocket science. With proper data and the right equipment anyone can accomplish a good HT.
Scott
I understand what you mean. If someone does a great job on heat treating, then I don't care about the little details either.
The thing is, there really isn't much of anything that is a secret about heat treating steel. One guy uses this oli mixture or whatever and another uses another. Otherwise the "secrets" of heat treating are, well not a secret. I can understand if someone doesn't want to give their competition lessons and wants to let them pay their own dues. Everything has it own little procedures and tricks of the trade.
If anyone actually discovered someting no one else knew about, it would be so valuable to industry that they could patent it, and license their invention for more than could ever be earned making knives... and still continue to use their invention making knives if they wanted. So whenever any maker talks about a secret process in heat treating, I roll my eyes and look for those clouds of smoke he must be blowing! :p
But like you say, the proof is in the pudding.
There is no secret. HTing info is only a mouse click away.:D
Scott
Neither Gerber nor CRKT has said much about dropping the quality of their steels. Many knives now just say "surgical steel" or "400-series" steel. CRKT, specifically, has quietly dropped many of their AUS 6 offerings to inferior steels, plus they make it impossible to tell whether a given knife has the better steel or the inferior steel. I mean, no identification marks, etc.
To make it worse, Gerber and CRKT (and perhaps others) are being continually advertised on eBay by retailers who are posting the old specs. So a buyer may think he's getting AUS 6, but he's really getting a mule grade 420 or less because no one's checking.
Meanwhile, I understand Chinese and Pakastani knives (five buck specials) are frequently made with no heat treatment at all. Even so, I was able to slice through heavy plastic with a Chinese Maxam that a popular Gerber model only left scratches on.
Scott
you mean like this:
Quite true, but I think the secret to HT is knowing what your doing. It is not so simple as you make it sound. Any knifemaker that tells me that HT'ng is easy and simple, will just make me walk away. It is far from simple.
I think what separates the great knifemakers from the so-so knifemakers is their HT and attention to detail. ATS34 can be great, mediocre, and junk depending on who does it. I had a Gerber ATS34 blade that was junk. Yet my Microtech 154CM (same thing) could hold an edge three times longer than my gerber. Microtech obviously has their steel HT'd by someone who knows what they are doing.
If you deal with only one type of steel and use that alone and have learned that heat treat and call it simple because of that, then fine. However, if you use many steels and do in house HT and call it simple, I'll be skippin along.
Here is the heat treat for O-1 that I took from Navachrome:
When does the clock start ticking? The clock starts when steel temperature falls below 1333F. There's no need to quench at or near the Peak temperature. So when to quench? Between the Peak and 1333F, it's your call. There's no reason to subject the blade to any more thermal shock than necessary, so quench at the lowest temperature you can and still be above 1333F.
Place the blade into the muffle and when it gets hot enough, watch/check for Critical, using a magnet. Now the question is how much higher to heat the steel? Time and temperature are both at play here. A slower temperature climb over a longer soak period is about the same as a faster climb and shorter soak. Use both the 1400F and 1500F Tempilstiks, 1400F is right at Critical. Let the temperature rise and if you hit 1500F then withdraw the steel. You'll have the temperature bounded, lower and upper, with Tempilstiks. Shoot for 50-100 degrees above Critical and a soak of 1-3 minutes.
Withdraw the blade from the muffle and as it cools, watch the color change. Know what Critical looks like and quench right as you pass Critical going down. If you start seeing 'shadows' move across the steel you've hit the recalescence point and the steel's too cool to quench. Put it back into the muffle, go back up to peak, soak a bit and try again. This routine can be practiced with 1018 and although it won't harden you can get the procedure down.
One important point to understand: When the steel has reached Critical during the initial heating phase, the magnet test will work. However, the magnet doesn't work coming off Peak during the cooling phase. Further, the magnet won't work until the steel has cooled below Ar1 and is heated again. Steel needs to be 'reset', as it were.
Once the quench begins, it's off to the races, the clock has started. We need to get past the nose and down to maybe 900F in a second or so. That's pretty easy, cool until the color disappears from the steel. When the color is gone the steel is cooler than about 900F. At this point we have time, 15 minutes, to drop the temperature to 130F. In particular, we want things to happen slowly during the Martinsite transformation, about 450F to 130F, that's when the blade is getting hard. It doesn't happen during the quench, although that's where the drama is, it happens during the transformation.
Quench for less than a second--plunge and withdraw. If there is any color, immediately plunge and withdraw again. Be sure and get to 900F or cooler in under two seconds. The time period for plunging will depend to a large extent on knife size and thickness. What you want, when you withdraw from the initial plunge, is the color gone out of the steel, but that it's still hot enough to quickly evaporate water from the surface. These are the two temperature tests to bracket the blade's heat--no color and almost instant sizzle.
Now you have plenty of time. Take you time. You'll need something like a wad of wet burlap that you can touch with the back of the blade to cool it. Slowly, draw the heat out of the blade. Touch and sizzle, touch and sizzle. The sizzle should get longer and less violent until at around a minute or two there not a whole lot of sizzle left. The blade should be somewhere around 450F. You can test this temperature by watching tempering colors, you'll want straw yellow. Get to 450F within two minutes. In many cases, you can just let the blade air cool to 450F.
Rest now and let the blade air cool in air. You want to make it to about 130F within 15 minutes. Keep an eye on things, it wouldn't hurt to have an egg timer running at this point. Make the 130F/15 minute-mark and you've brought the blade in for a smooth thermal landing, perfect! When you can hold the blade in your bare hand--warm, but not hot to the point of discomfort, then begin the temper/draw phase of heat treatment. Discomfort is wondering when you can set the blade down, when you feel you could hold it indefinitely the temperature is about right. Don't let the blade drop below 125F. With thin sections, the step from 450F to 130F will often happen in less than 15 minutes so it doesn't hurt to insulate the blade and check it every few minutes. Extending the time for Martensite transformation to a full 15 minutes will be repaid many times over. The whole transformational magic happens during this period and it happens best when it happens slowly.
Immediately place the blade into a kitchen oven preheated to 450F (see tempering chart below). Using an oven thermometer wouldn't hurt. Close the oven door and wait two hours. Retrieve and let cool in air to room temperature. The resultant hardness of O1 steel should be around HRC 60. That's it, that's the heat treatment.
First, we hardened by bringing the temperature down from 1475F to 130F in a controlled manner, then we softened a little by tempering in the kitchen oven. See the tempering graph below.
It should be noted that 130F water and 130F steel are two very different things. Putting your hand in water that hot will create discomfort if not injury.
Make any adjustments to this procedure as you see fit and/or as results warrant.
___________________________________________________________________________
simple carbon steel, yet the HT can be tedious and complicated for such a simple steel. What happens when you use a more complex alloy steel. Don't things change a lot. My guess would be yes. Paul Bos has taken this into account because they have the means.
I understand why knifemakers like Carson/Lightfoot and others still like 440C and ATS34. If treated right these steels can do wonders. It's to bad that junk mfg and HT'ing has given these steels such a bad name.
I'd have to agree with you Cobalt: heat treating is simple in that it's not hard to find out the basics... getting it right however down to the last details is the difference between a master and a, well NOT a master. It's not rocket science but it IS science.
It's like baking a cake: Having the recipe doesn't make you a great baker. There's a lot of years of basic knowledge and experience that go into the recipe which you don't see right away. But you taste it in the finished cake, or don't, as the case may be. Same with heat treating: like you say, same steel can be either crap or great depending on the skill of the heat treater.
Cobalt, no need to get dramatic:D I was merely stating that there is plenty of info on the internet for someone to learn how to HT. There are metalugury sites that have detailed explainations on how to HT. If you don't have the right equipment then you can't properly do it. Every steel has a different temps, soak times and tempering temps that need to be followed. One needs to experiment with their equipment to see what works best for them.
Scott
