Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Lately I have seen a lot of advise that roughly says,"Get it hot and forge it....".
Lets think here...
How hot do you need to get a piece of steel to forge it...Red, cherry, maybe orange?
If steel quenches at 1550F isn't it a good idea to forge at a lower heat?
Most carbon steel forges at around 2200F, and you should stop forging at around 1600F. Some steels are even higher. If you forge until the steel is barely red, (or worse - black) you have gone way too cool.
To forge steel you need to be able to reliably get it to a yellow orange heat (2200F) and not burn it up with a lot of excess oxygen. A leaf blower in a charcoal grill or wood stove will get it that hot, but it will be a heavily oxidizing atmosphere. A cutting torch will do it too, but is hard to reliably heat the whole blade.
A simple forge made from a piece of any scrap 8-10" round metal (pipe, water heater tank, propane/freon tank, etc.) will do the job perfectly. You can use it to do the HT ,too.
I know a lot of folks started with a one brick forge, and that will work in a pinch. But for as little as $100 you can build a forge that will get you through several years of bladesmithing with good results. The first knife you sell might pay for it.
For ideas and materials, go to Darren Ellis' site - http://forgegallery.elliscustomknifeworks.com/
and click the refractory and knife supplies. There is a FAQ page that has a lot of info,too. Darren will help you if you are totally at sea (I may have dated myself with that statement). He is a first class fellow and knows his stuff. You won't beat his prices either.
This is where I chime in about the steel you forge....
All lawn mower blades are not 1080.
All springs are not 5160.
All files are not 1095.
All hammer heads are not O-1.
All 5160 from a Admiral is 5160.
All 1095 from a Crucible is 1095.
All O-1 from Pop's is O-1.
All 1080 form Aldo Bruno is 1080.
Using a know steel from a reliable source will give you:
1) A known steel.
2) Charts and temperatures to work with.
3) A place to ask questions and get good answers.
I think that is enough to (hopefully) get some of the newer knifemakers headed in a better direction, and to get some of the well intended advice redirected to folks with more experience (working "found" steel is fun....once you know how to determine what to do with it.).
Stacy
Lets think here...
1) A known steel.
Stacy
