- Feb 17, 2009
OK so if anyone is like me they would get a blade done have it tapped up, no matter what kind of tape, and take the tape off only to show the tape left a mark on the blade or a scratch appears as you attempt to remedy the crap the tape did to your finished blade. I actually had blue tape pit S35VN before.
So on the last couple of blades I tried something different for me and it has worked well. This is the Tanto I am currently working on and before I fit the guard had the blue tape pit the blade a wee bit.... I was furious when I removed the protective tape to find it.
So I decided to go a different route. I went to my Grainger catalog and remove a page, the paper is very smooth, I wrapped the blade with the paper and then used electrician tape to wrap the blade. The electricians tape stretches and as you wrap it around the paper it applies enough tension to hold the paper on and no tape contact is needed.
I did this on a couple other blades as well and have found it to be the best method for me so far at protecting the blade from the environment as well as from the tape.
Give it a try if tapping the blade has been giving your troubles. The catalog paper is thin enough and strong enough it does not get in the way and is easy to replace when needed
