- May 15, 2003
Had a few people ask me how I load the springs so the wife took some pics while I
tried to show how I do this. I realize there are other ways but this way allows me to check the action before I drill the center hole of the liner.
First drill the front hole in the liner then the rear when that is done lay it out on a board then I use a piece of brass that I fasten down with wood screws I think the pictures explain it pretty well . Then I use a clamp and check the the spring tension or load on the blade with the liner under the knife. when i get the load
were i want it I simply go to the drill press and drill through the center hole of the spring and drill the liner then take the liner off and match it with the other side and thats about it . I hope this helps as I have received so much help over the years from you folks .
And here I am wife says im cute
