Was good meeting you all. If you guys ever need anything, just PM me if you didn't get my contact info at the bbq.
For those of you that were interested in the effects of cryo treatment, dial your BS filter all the way up and enjoy.
From asia (high probability of being a complete fabrication but might just be plagiarized) and not actually a published journal. That said, most of it seems possible.
http://www.kau.se/sites/default/files/Dokument/subpage/2010/02/48_671_684_pdf_16802.pdf
Slightly more believable paper but notably from an industrial source and lacking error bars for all of their charts which is a pretty bad sign. Their EDS output is BS but their SEM micrographs are decent. Interesting output in terms of loss of impact resistance but again, take it with a grain of salt. Even if this data is correct for this steel it doesn't translate to every other steel.
http://www.airproducts.com/~/media/...etals-cryogenic-quenching-steel-revisited.pdf
Review paper on the Cryo treatments. Also from asia and published in an online journal (will publish anything as long as you pay them to) but it is properly referenced. Figure 6 demonstrates what I was talking about hold time. After 30 minutes it basically doesn't make any difference for hardness. Table 2 has a good breakdown on steel comparisons with different soak temps. D-2 is a rockstar at 817% wear resistance and AQS is a redheaded stepchild at 4% decrease...
http://research.ijcaonline.org/iccia/number9/iccia1068.pdf
If the decrease in impact resistance does correlate with soak time, and given the trivial changes in hardness and wear resistance over time. Kinda looking like half an hour is the best trade off if you care about impact resistance.
-Sandow
