I don't think you can answer "how important is splitting wood in a survival scenario" by referring to general experience in the outdoors. When we go out in the woods and build shelters and light fires, that's not a survival situation. What matters on an ordinary day in the woods isn't always going to matter when your life is on the line.
:thumbup:
How important is splitting wood in a survival situation? Depends on the situation.
How true. Priorities will differ. Experience may teach that splitting wood is commonly necessary. Note above comments based no actual experience.
The difference between practice and the real thing is that in the real thing, you aren't in control. You're at the mercy of the situation.
In many instances, those in a survival situation arrive at that point by a series of poor choices. Better choices, at several stages of the progression, would have totally prevented, or greatly reduced the severity of, the emergency. That is, the "victim" worked his or her way to being "out of control." Once the emergency arises, you
may still be in control of your fate due to the skills, knowledge, equipment, and mental faculties you bring "to the table" -- or not.
If you feel you are "out of control" you are less likely to survive. Feeling "out of control" -- helpless -- is a common way people who panic describe thier mental state.
Usually, it's not very important at all. The importance of fire, even in northern climes, is usually overstated. I can find dozens of accounts of real-life survival situations in which lighting a fire was not necessary, or was a question of greater comfort rather than staying alive.
Given that fire is much more than a source of heat, it is generally accepted that fire-making is as important as any other skill and often more important than any other. But, as you observed, it all depends. SO Cal in June with a working cell phone and plenty of safe water or Wisconsin in January out of cell service and only a beaver pond for water?
But ... the bedrock truth of outdoor survival is that whatever you need most in any given situation will be the thing that's most difficult to attain. The time you most need a fire, a fire will be most difficult to make.
If it's easy to meet the need, the need is not critical? Can't see that. If it's life or death to get a fire going because you took an unplanned swim in frigid water, with frigid air temps, far from any shelter or spare clothes, fire is still needed even if you are Joe Pyro with mounds of dry material to burn.
Hypothermia kills, and when you're cold and wet and the wind is howling, you can bet all the wood you can find will be cold and wet, too.
That is sometimes true. Hypothermia occasionally kills and can kill because wood was cold and wet. But people can get cold and wet when there is no rain or wet snow around and when dry small material, tinder, and kindling are easily found. I have found people cold and wet in the California mountains when it had not rained in weeks. They got wet with sweat at 8-9,000 feet and were shivering with cold. (No wind-resistant clothing and no means to start a fire. Duh!)
Again,
So, you need a range of skills and abilities to meet a range of possible situations. One of them being, as you say, splitting wood.
