Respectfully disagree (I mean this; I've always respected your posts here, and still do).
It does take quite a bit longer to get it there, but D2 responds BEAUTIFULLY to careful, high-grit finishing. I've been tinkering with using hard-backed strops of textured paper, canvas or linen-over-wood, using diamond and/or aluminum oxide compounds. With the right choice of compound, a very firmly-backed strop is D2's best friend; 'softer' strops of leather or other similar material are more prone to rounding off D2's carbides, as the grit progression goes higher. With harder strops, I've yet to see how far D2 will go, in continuing to refine, refine and refine; it just keeps getting better. And it's only 'difficult' or tedious in establishing the first edge of good geometry and chosen finish; once it's there, it's a cinch to maintain on the same hard strops.
The flipside to all this is, because it will respond so well at higher finish, the fundamentals are also good to make it excellent at a coarser finish, which is easier to apply. I'm sure this is why many favor it at a coarser finish; it responds very well, and quickly. Coarse through EF diamond hones are perfect for D2, in sequence or individually, according to preference.
Edge retention is edge retention; it's a physical property of the steel itself, regardless of chosen edge finish. D2 will sing with whatever finish one chooses to throw at it, if one is patient enough to see it through. :thumbup:
So far, I've done all three blades on my Queen 'Cattle King' stockman, a Queen Country Cousin, a Buck 118 fixed blade (limited run in D2), and a Queen #92 fixed blade in their slightly older Carved Stag Bone; I keep tweaking them higher in edge finish (near-mirror or better), and it just keeps responding like gangbusters.
David
