Yes. Case is still selling CV blades. But they are not made from 0170-6C. They are made from another alloy, which Case has made to their own specification.
There is no AISI designation "50100B". It's just as much a custom name as 0170-6C.
There is an AISI designation 50100.
http://www.efunda.com/materials/all...ISI_5046H&show_prop=all&Page_Title=AISI 5046H
The only modifying element is Chromium. No Vanadium. No Moly. No nickel.
When you add "B"to the AISI designation that means the composition has been modified and is no longer a standard AISI composition. So when somebody says "50100B" they are saying it is similar to, but measurably different from AISI 50100. In this case, I would guess they are saying that it has the same Carbon and Chromium content as 50100 (which it does), but that there are other changes to it. The "B" does not indicate what those other changes are. So unless you happen to know the composition of 0170-6C, or "50100B"you can't buy it. KaBar still has the Sharon catalogs, so they know exactly what composition to order.
►Cold Steel "Carbon V" was originally 0170-6C, because the Cold steel Carbon V knives were made by KaBar.
►Carbon V started as 0170-6C when the knives were made by Ontario. But the alloy composition was changed and the Nickel was dropped from the composition. Unsure if the modified 0170-6 alloy had a name other than "Carbon V" when it was made at Ontario.
►When the Cold Steel Carbon V knives were made by Camillus they used the modified 0170-6 alloy. Camillus called that alloy 0170-6C. Camillus also used 0170-6C on some of their own knives.
I hang out some on the KaBar forum. You learn things. Especially when Tooj posts.
