- Feb 24, 2000
I have been asked that question more times than I can remember. I usually make knives four or five at a time, and did not have much of an idea how long it took to make one knife from start to finish. I decided to keep track of my time.
Speed is not anything I aim for. The old saying "Haste makes waste" is true.
I decided to make a simple 7" overall guardless knife out of CPM 154CM steel.
I actually made four knives and then divided my time by four to find out how long it took to make one.
From the time I scribed the pattern on the steel, cut it to length on a chop saw, ground the profile, drilled holes, tapered the tang, ground the bevels using 60 grit, 240 grit, 400 grit then hand sanded with 220 grit and 320 grit for the beginning of a satin finish was one hour for one knife.
I then sent the blades off to the heat treater.
I hand sanded the heat treated blade to a satin finish which took 30min for one blade.
It took 30 minutes to fit and epoxy the handle in place for one knife.
It took 30 minutes to grind and buff the handle to completion.
My time so far was two hours and 30 minutes.
I then made a sheath for the knife. That took 46 minutes.
My total time was three hours and 16 minutes for this one knife.
I was surprised. I would have thought it would have taken a lot longer.
