- Oct 20, 2004
Hi Everyone,
I am in the process of grinding my first blade. It is 1080 which is 1/8" thick about 1 1/4" wide and about 4" long (from plunge to tip). I am using a craftsman 2x42" sander and attempting a flat grind. At this rate its going to take 3-4 hours to grind it to the point of heat treat and probably another 2 hours after its hardened (I'm assuming...I should know better and multiply that by 2 or 3 since thats how things normally go). Does this sound right? The steel is soft and is really easy to drill, maybe I'm not using a coarse enough belt? I am using what it came with which is either an 80 or 120, should I go coarser? Also, all the production blades I have, have a 'mirco-bevel' where the last 1/16" or so next to the blade has a wider angle (more obtuse). Is this how everyone else makes there blade? Is this angle put on with a stone or is it done on the sander? Sorry for the newbie questions but any help is greatly appreciated!
Thanks, Ryan
PS On a side note, am I the only one that the search function only works about 10% of the time?
Thanks, Ryan
