Jason B.
- Jun 13, 2007
Using basic abrasives carbide size will limit how refined you can go. Once the abrasive reaches the same particle size as the carbide then you will no longer be able to effectively sharpen the knife. So lets say you are using waterstones on a steel that has vanadium carbides with an average carbide size of 2u. Once you reach around an 8k ish stone , you wont be able to further refine the knife effectively.
Switch to diamonds/CBN , or enhance the waterstones with a spritz/drop of some , and the problem is immediately solved.
That's a good theory but you lose effectiveness long before the carbide size comes into effect.
The volume and carbide type are much larger contributing factors. Once the volume hits 4%+ with an optimized HT all but diamond CBN and to some extent SiC are about the only options. Waterstones below 1k have a fighting chance because they tear at the matrix of the steel but above 1k the Vanadium carbide volume yields too much resistance to the softer Aluminum Oxide abrasive most commonly found in waterstones.
A good example of this was a K390 Mule team I sharpened up the other day. With 9% Vanadium and 1% Wolfram it stopped my 1k Shapton Pro in its tracks, actually started polishing the bevel.
