How many of you just use a file?
Inthewind
Platinum Member
I just started making knives, 1 finished and 3 on their way. I have a harbor freight 1x30 belt sander and i like it a lot. I have just started learning just how important the file is in getting a flat grind on a knife. I use the belt sander then i switch off to the old Nicholson file to flatten out the grind. I was just wondering how many of you use only the file?
I forge most of my blades very close to shape. There are many knives where I simply drawfile to true up the flats and work down the edge. After heat treat, I use stones or sanding blocks to finish. I enjoy simple tools. My grinder is a definite convenience(especially for the volume of a fulltime maker) but not crucial to the craft.
I prefer using files to grinders. I've made several knives (and KSOs) using nothing but files and sandpaper.
I often use a file to true up grinds after using the 1x30, if I don't want to change the paper on my disc grinder. I also use a chainsaw file to clean up the plunge cuts a bit.
-Xander
I used to just use files. Now I have a HF 1x30 and its easier on my back than filing for hours. After I make a new platen set up it should be even nicer, I will definitely post up what I did once I finish.
Xander nice chatting with ya on Wednesday, I think you are gonna dig my mods to the HF.
I'm new to knifemaking myself, working on knife number 2. I live in an apartment, so I use a file pretty much exclusively. I do have a 4x36 sander, not the best setup for knifemaking, but it helps for some things. I like filing the whole thing. No heat involved. I've been wondering myself if I would benefit much from a normalization cycle of CRA 1080 from AKS that has seen NO heat during the shaping.
Anyways, from a newbie, here is knife number two (yes, it is a copy of a popular design). I'm going to try my own design on knife 3. Something like a utility sheepsfoot with a full grind on one side only. Chisel grind, I think. I hope this pic comes thru. I'm new at this, just got a photobucket account.
add
My first four were made with only files and sandpaper, but I really hate filing full flat grinds as it takes so long. I am about to pickup a 1x42 in the hopes that it makes that operation a little faster. I am still planning on using a file to even out the grind, and I do a fair amount of draw filing in order to refine the profile.
I made 19 with files and sandpaper before I got my Craftsman. 213 more knives and a NWG since then. I still use a file sometimes in parts of the process, but I can't remember the last time I put a file on a bevel.
I use a file but then again I am brand new at this. I just got a 2x42 and used it to flat grind for the first time. I flat ground it roughly, then cleaned it up with a file. I love using a file it feels magical.
I only have a file. :p It's a bit annoying in that it takes so long, but knifemaking is a hobby for me, so it's alright.
Using a file takes a dedicated and motivated knifemaker I did my first with a file then built a "no weld grinder" then bought a "grinder in a box" and finally monday a KMG should be delivered to me, my suggestion would be save your money use the files till you can afford a good grinder. But after that I use files only when making Guards.
Anthony
I DREAM of the day that I can acquire a belt sander. The 1x30 would be nice to have, a step up from a file. But, as I understand it, buying, bartering, begging, or building a 2x72 is the way to go. I do like the use of files, however. I like knowing that NO heat (relatively) goes into the steel, and the control that varying file shapes provide. But the proper belt sander can save on many variables.
