- Jul 14, 2020
Ah, gotcha.it was mentioned by elementalbreakdown that he believed a handful of us use it on our knives.....so I've been continuing the joke......
nope. I don't even oil pivots unless the knife gets wet or really needs it.Olive oil goes rancid. Yall oil your knives?
My pivot got real gritty after Pompeiinope. I don't even oil pivots unless the knife gets wet or really needs it.
then I use whatever I got...bertolli or Pompeii......
do ya age whine in the cheese cave too?It's only necessary if you live in something like a cave or dungeon used to age cheese, otherwise regular knife /gun oil is definitely preferable
I try to but it keeps getting moldy(I was referring to the whine, not the terlet) course it might be because my supplier is always sending those sour grapesdo ya age whine in the cheese cave too?
Good trick for that is Tilex Mold and MildewI try to but it keeps getting moldy
Of course I bleached, changed the wax ring, and last time the plumber was over for stuff I can't do with soldering asked wtf the deal is and the answer was that it's not active mold but due to it being a basement toilet right next to the garage, in about a week the actual oil/dust from garage and single week of mildew creates permanent discoloration immediately that no amount of bleach or chemical will fix.Good trick for that is Tilex Mold and Mildew
Tucked into a sock for easy deployment
Get some frog lube that stuff takes it right off and oils your blade at the same time.Generally speaking, the things I cut with my pocketknives are dry items. As a result, it really doesn’t get dirty enough for a good cleaning very often. Just a quick dry-wipe of the blade is all that I usually need to do.
Packing tape goo is a whole different story. I clean that stuff off as soon as humanly possible with an alcohol based adhesive remover called Goof Off.
