- Jul 13, 2011
I got that thunderbird insert for my zippos and it is really inconsistent? Do you have the same problem? I've heard some do and some don't.
Hi Tim,
I did have problems with the Thunderbird insert at first until I learned that the problem stemmed from the fact that I was not refilling it correctly. You have to follow certain steps in the refill exactly, or it will not perform optimally. It's not as simple as just sticking the butane can into the lighter and holding it there. Here is a video which shows you the steps in pretty good detail:
[youtube]0ttjmi4PK0A[/youtube]
Another thing that helps performance is if you dial the flame bigger and go with a larger flame (two inches high or so). That gives you almost-Zippo wind resistance. If you find that your flame on maximum is still too small, you can actually turn the dial further than the highest flame setting, just use a little more pressure while turning, and it will engage and open up more.
I think the Thunderbird insert (the butane yellow flame version, NOT the torch version), is the greatest invention in lighters since the Zippo, not kidding. It solves all the problems of a Zippo (i.e., that damned smelly, irritating, quick-evaporating lighter fluid).
cheers
Mag
