coloradowildman
Platinum Member
- Oct 28, 2009
It seems to be a good larger woods blade, the newer saber grind model is more front heavy so its better at lopping off limbs and such, I did medium hack and whack with it (I call it medium some other people seem to call it hard). For steel on wood it seems to do fine. I brought a SAW (one of the most important survival tools) along to cut the more bigger offending woody botanicals, and it split them fine for the fire. It can carve...but the rubber hilt can get in the way. For Wieldinessy, well its a bigger blade with a heavier front end than the hollow grind one, but it depends what you want to use it for, remember its a big blade and for doing little twiddle things it would be some what unwieldy. The tip I don't bash my tips in to things to test them, but the hollow grind one did fall from fridge to tiled covered concrete floor and had a slight bend at the tip. No breakage. I'd class this knife like a BK9, jack of all trades and master of a few. The rubber hilt and its "Guards" can get in the way for smaller jobs, buts its curved blade makes it a bit better cutting it seems. Like the BK9 I find its more of a multi-tool in the woods, and can step up and do heavier things if needed.
For fighting and deterrence I think the hollow ground is better, its literally flashier (better and psyching some one out), better balanced making it faster in the hand. But remember, you got not no real guard, the longer blade may help against shorter knives is my guess on things.
The hollow ground is better at carving due to thinner blade. But then this larger knife with a saber grind, I find it can carve as well, just the hilt gaurd gets in they way and subhilt makes things odd some times. But I can live with the latter, I usually pull out the Recon 1 for dittle whittling and such. (fancy wancy fu fu feather sticks). I like the Aus8A CS Marauder (saber grind one) for its durability and able to a lot of jobs, and in wet environments/snowy/moisturerich not having to have to baby the knife to protect from rust is a really big plus!
And finding out in this thread, that Aus8a is awesome, made me glad I could get two saber grinds while I can. (really it should be Aweful! As having some Awe is not as good as being full of Awe! So it should be AWEFUL! RIGHT?)
Cool, thanks for the info!
