I have seen the numerous threads that cover lock stick. But how much if any falls within the normal range? Should my small Sebenza be void of of any noticeable lock stick? I have a pretty new small Sebenza and there is a slight but noticeable sticking point you have to break through when disengaging the lock bar.
In comparison I have a Sage 2 with zero lock stick. When disengaging the lock bar you feel nothing. Lockbar tension is easy on the thumbs and smooth as can be. This is supposed to be an homage to the Sebenza but is some ways feels like an improvement.
I've seen posts where Sebenza owners have sent their knives back to CR and it came back with no lock stick. I've also seen posts where owners have stated the lock stick is normal. If any at all is normal than you would think CR would acknowledge rather than just fix?
Thoughts?
UPDATE:
So I just took apart my Small Sebenza to put my new lanyard on. I washed the scales with dish soap and hot water. I made sure I washed the lock bar/detent ball area well. I did the same with the blade/tang. When reassembling I place very minimal CR grease for the washers and that was it. After re-assembling it seems to have that smooth as glass feel and no lock stick. Im not sure what the difference in this take down was but this is the smoothest it has ever been! And so far the absence of grease has eliminated the lock stick. Knock on Wood!
Thoughts?
UPDATE:
