OK,
When you quenched the blade from 1500F (approx), the blade was Austenite. Hopefully, it dropped from 1350F to below 1000F in less than one second, and remained Austenite ( and didn't start converting into Pearlite). The blade now has until it drops to about 400F to go before it converts to brittle as glass Martensite. Once you counted to 5 or 7 you had taken more than enough time, I use a three count. By removing the blade at that point, you are now dealing with rubbery Austenite. You can straighten it with gloved hands, or give it a few taps with a wooden mallet on the anvil. Place a piece of wood on the anvil to help slow down the cooling ( the anvil will suck the heat from the blade fast). When you feel the blade start to stiffen up and resist any more straightening attempts......STOP....or it will soon snap in two.
Here is my quench procedure for 1080/1084:
1) Austenitize to 1475F and hold for about two or three minutes to equalize.
2) Quench in 120-130F fast oil, and count to three. During the quench I move the blade rapidly up and down.
3) Remove the blade quickly and sight down the blade to check for warp and twist. The blade will smoke severely when you remove it and may even burst in flames...so do this in a well ventilated shop or outdoors. A quick wipe of the blade ( with an old towel) will remove much of the smoking oil. The blade is HOT, so wear heat treatment gloves.
4) Remove twist first. Have a vise opened a crack to drop the blade between the jaws and un-twist it. A 2X4/2X6 with a 1/4" slot sawn in it does even better.
5) Warp is easier. Use gloved hands or a few taps with a wooden mallet and a wooden anvil surface. Steel hammers and steel anvils will dent the soft steel easily as well as suck the heat out faster, so wood is good. An old piece of a baseball bat will work fine as a mallet. I call my wooden hammer a "swacker".
6) At some point in time the blade will start to stiffen. You will feel the difference easily. Quit all straightening attempts at this point. Once the blade gets to around 400F it starts converting to martensite. The percentage of martensite increases until about 200F when it is above 90% . At room temperature it should be near 100% martensite. Any straightening remaining in need will have to wait until after the temper cycles.I call this secondary straightening, and do it at 400F. You can heat the blade to 400F any time you wish ( as as many times as neded to get the job done) and gently straighten any remaining and newly discovered warpage. This will not affect the blade's temper at all. ( unless you tempered below 400F.)
If you want to experiment with the time you have and such, use a piece of 1080/1084 and heat it as if it was a blade. Quench and pull as noted above. Have one friend use one of those inexpensive HF laser pyrometers to check the temperature. Have another friend with a stop watch jot the time and temperatures down as the pyrometer person calls them out. Wipe off the blade and go through some bending and straightening procedures ( you will also discover how plastic austenite is), with the friend shooting readings as often as he can. Keep on "adjusting" the steel as the temperature drops and feel it stiffen. A little farther on it will snap like glass. You have tracked the cooling and conversion of the steel. This should give you a hands on feel of the different points on that curve.
Trying this in air only; using wooden straightening tools; and using a vise ,metal hammer, and steel anvil. This should teach you ( and your friends) about the ways these parameters affect the window of straightening time on this steel.
Now, the disclaimer - The procedures above for straightening are for 1080/1084. They should work for most low alloy steels in the .70 to 1.00 carbon range. I usually try and get it done in about 30 seconds.
High alloy steels have vastly slower conversion rates. On some steels you have many minutes to affect any straightening needed. Air hardening steels ,and steels like 5160 and O-1 are in this group. Use the same straightening procedure, but take your time.
