Actually, the best thing to use is Stoddard Solvent. That's the stuff inside of WD-40 that makes it such an effective cleaner. Use it, and you won't have to coat your leather or denim with the mineral oil that is the other component of WD-40. Stoddard solvent leaves no residue of its own.
You can find small bottle of it labeled "Odorless Paint Thinner" in any art supply store.
Lanolin hand cleaner leaves zero residue as well. Nothing but dry, raw, leather, screaming for a treatment of whatever. If you've never used it, try it on a small piece.
I use a heat gun - same concept, just hotter.if you're using any of the stick oxides, heat the leather and the oxide first with a hot hair dryer
Not really - my goal is to get an even but very thin layer. The compound I have is a really hard stick crayon type made by Porter Cable for use with a buffing wheel, so it's hard to just manually rub it into leather, and you can end up with clumps on the surface. I want it sort of soaked in so it doesn't come right off on the first knife I strop. If I had a different stick of compound with more grease to it, perhaps it would go on smoother and I wouldn't need the heat. I don't always use the heat gun, but it seems to make it easier when charging a fresh strop the first time.Probably get a good, thick layer that way, eh?
Stitchawl
If I had a hand-held hair dryer I'd probably use that instead. I have in the past tried to soften up the compound using a butane lighter but that makes for clumpy spots on the strop that take some work to smooth out.
Maybe I use too much, I dunno. In about 5 years, I have used up about 1/4" of that Porter-Cable PCPC5 green stick, and that's from using it on two leather strops and who knows how many impromptu cardboard or paperboard strops. At that rate it should last me 90 years. Not bad for $2.88 plus tax.
I do highly recommend S stitchawl 's recommendation to case your leather strops before use. I bought some good veg-tanned belt leather at Tandy, cut off about an 18" section, and hand-cased it using a rolling pin. Made for a nice, firm stropping surface. I will reiterate - if you are going to make your own strop, CASE THE LEATHER.
