"Nonsense, I and many others have used many different lubrication mediums than the CRK grease with zero problems over literally years."
Excuse me, but you may think it is nonsense, but that's what CRK states. I was just repeating what I was told. I know very well, as does anyone else who reads this forum, that many people do not use the CRK lube.
The study of lubricaton is a whole field, called tribology. I find it kind of funny that people pay big bucks for a knife, but then don't follow the advice of the manufacturer when it comes to ~$10 for lubrication. I wonder if the same person ignores the lubrication specifications for their car's transmission, engine, etc. I know an engineer who thought he new better than Ford...his wife certainly didn't appreciate the blown engine. Trouble with the guy was he was an electrical engineer![]()
A knife is not an engine, gear box or wheel bearing so I don't really see the comparison, but please do explain to me how using different lubrications is going to have a detrimental affect on a knife ? That is what you're suggesting with your analogy I presume ?
Hey, Hazey calls it nonsense, but it's what the manufacturer recommends, and it's not expensive. Why not use the right lube?
With knives, the type of lube is important. If you flip a bali, you may love Mil-tech. Benchmade used to suggest Tri-flow, now Mil-tec, and guess what...Mil-tech is better. If you use a slipjoint, a light oil, such as mineral oil is best given the metal/brass contact surface. Mil-tech can be too viscous and you couldn't even get lithium grease into the cracks to lube. Oil also protects from rust. If you always sharpen your carbon steel slipjoints using honing oil (a light oil that penetrates easily) you find you get very little rust. But if you use the sharpmaker, no oil, you need to regularly oil your blades. Unlike a sebenza, my Bob Terzuola frame lock ATCF is designed never to be lubricated. Bob recommends just blowing out the knife and if really sticky, washing it in hot soapy water. Oiling, and god help ya using grease, will attract dirt and lint and gum up the works. I've been using the blade for 4 years w/o oil.
However, this is the sebenza thread. Per Customer service, grease is best. I don't know exactly why, but I'd bet it's due to wide open space between the handle slab and blade, plus the operation of the pivot and the "holy" washers. CRK customer service told me the yearly lube and the grease helps stop corrosion in the pivot area. Remember its "stainless" not "rust proof."
Ooohwee..."strawman argument"...must be a college boy. The principles of tribology that govern knife lube also apply to cars. If you put light oil in an engine and it needs heavy, you'll get more wear. Just like in a knife. If you put too heavy of an oil in your car it will take more force to operate (wich creates more heat) and maybe sieze up, just like in a knife. With a sebenza if you use the wrong lubricant, you can take it apart and clean it; with a car, sure its more dramatic, but its the same priciples of tribology at work.
