- Mar 1, 2010
The ARK is H1, and is a handy little thing, but I don't know if you'll want a sharp tip on a dive knife(?).
I'm personally not a fan of a sharp tip on a dive knive. I see no need for it. I'm not stabbing anything while I'm in the water. I'm not a knife fighter on the surface, I'm certainly not going to go to battle with the wildlife below.
Does grinding it down remove anything that might make it more susceptible to corrosion? Like the heat treatment... does that also create some kind of finish that would be removed by grinding it?
Did you keep track of the conversation? I was referring the the H1 ARK that you said you didn't like because of the pointy tip. Are you aware that H1 is almost totally corrosion resistant? You're trying to shoot down every suggestion that will fit your needs and you seem to be trying so hard to not accept any of the suggestions.
Or are you just bent on having Spyderco make a custom knife for you? Somehow right from the start, I knew you were heading here. I've been here long enough to have seen a lot of posts like yours.
