Cliff Stamp
BANNED
- Oct 5, 1998
Professor :
It doesn't apply specifically to the Sebenza, it is a general rule that deformation blunting is highly correlated to hardness. Physics doesn't make exceptions for Chris Reeve.
JoHnYKwSt :
[Reeve should use a lower edge angle]
I always thought they did, the blades I have used (older ones) were definatly not at 20-22 degrees. If this is a case of S30V influencing the geometry it certainly was a decline in performance.
It was listed as 57-59 initially, I have seen three different ranges now.
High alloy steels at low hardness levels are the worst possible combination. You get the weakness of the lower HRC and the lower machinability of the higher alloy. If you are going to go soft there is little benefit to hard carbides because the edge can't cut well if it is bent regardless of the aggression of the carbides.
-Cliff
I don't buy the "S30V at lower RC is a bad thing" concept as has been applied specifically to the Seb.
JoHnYKwSt :
CRK's S30V is not 57Rc, it is 58-59.
As for the 420HC comparison, that sounds like quite a stretch.
-Cliff
