Where are you guys finding phonebooks? I honestly have not seen one in years. Years. I was told to drop by local ethnic markets, but there has to be another way to obtain them. FYI, my home does not have landline service...
Now that was an interesting read. Makes a lot of sense.Good question!
In my mind, and I am a traditional knife user: (that means that I whittle in wet fresh wood, butcher fresh meat, butcher fish and so on. I very seldome slice cardboard, nylon, paper, plastic and ao on as city people do).
A knife shall only be as sharp it need to be for its purpouse, not sharper, or duller, then that.
If i shall whittle in soft wood I use flat edges in 18-19 degrees and they work dine and hold dor the job. If I keep the knife and start ro whittle in hard wood the edge need more power - and that destroy the edge fast = the edge get dull fast.
Har wood need higher edge angle, oak for example need 23-24 degree edges to hold.
Low edge angles has less material in and behind the edge = they are more sensitive and you cannot use hard force when using them. Steep edges has more material in the edge = they are not sensitive, you can use more force and use the edge in harder materials.
Two flat and smooth surfaces that meet eachother in a low angle = sharp.
100% flat can only be made with the help of a good sharpening tool.
Smoothness = depends of your choice of sharpeners and hiw fine they are.
Meet eachother =up to you to control
Low angle = the knife edge hold 40 degerees or less totally.
In Scandinavia our traditional edges are around 20 degrees total. In US edges often holds 40 degrees total. A Scandinavian axe holds around 35 degrees.
As you can se, edge angles varius a lot depending on where theyvare used in the world - and to what.
Scandinavian traditional knife knowledge says that you only slice with a knife = we never batoon or chop with knifes - unless the knife is a real chopper = a knife special made for chopping.
In US people chop with their knifes = the edge must be steeper. That also means that the edge penetration skill is not so good compare to a Scandi knife on 20 degrees total.
The knifes purpouse:
If I have a good perfect working hunting knife and I make the edge hair whittling sharp I have change the knifes purpouse from hunting knife to a razor - and I can not use this razor as a hunting knife any more, it is to sharp. It will slice hole in the hud when I skin my game and it will slice hole in the thin hins that protect the meat from flys and other bugs and they can lay eggs in the meat.
My outdoor knifes have 3 degrees convex sphere and the cutting edge holds 26 degrees total. I carry one normal knife with around 10 cm long Scandi blade, and one chopper with 20 cm long blade. During 50 years in the mountains and in the forests they work perfect for me and solve all my problems. During the winter I also have a axe with me.
Thomas
I sharpen at knife shows and other occasional events. I do it mostly to fund my addiction to knives.What does that mean , semi-professionally?
FortyTwoBlades,
We all have special needs of sharpness depending om to what we use our knifes to do + we have standard needs for common outdoor life. Depending on where on Earth we live, how soft, or hard, the firewood are, if we skin beavers or deers, butcher games or fish = our blade design and edge angle differs.
If you need shaving sharp knifes outdoors and there edges hold for you - your chois of edge is perfect for just you.
I can not use beard shaving sharp edges where I live becouse they get dull very fast.
When using knifes outdoors you can go two ways in sharpening, often and little, and seldome and much. I am the often and little type of person becouse that method can save my life. I never let my edges get dull when I live outdoors.
Hair shaving sharp in my mind is a levell of sharpness tested on arm hair - when the hair so not pop when shaving. That is a nice levell of sharpness to hold on edges on outdoor knifes.
Beard shaving sharp is to sharp.
The sharpning process depends on where I am. At home I use sharpening tools, outdoors I go freehand mostly.
Thomas
As a young hillbilly growing up in WV, Dad said, son, there's two different ways to sharpen a knife. One was what he called his, "working edge." Not quite as steep, ground for cutting up cardboard boxes and the like. The other was what he and many of you called his, shaving arm hair finish. Dad likened it to me this way, son, if you sharpen a pencil real, REAL sharp, and then go and do some rough work with it, is that blade going to hold up or last very long under hard use? He said, that's when you use your blade with the working edge. (Yea, we're talking about a Stockman type knife)I used to obsess over sharpness when I was younger, but it became less important to me as I went through life. I finally got to the point where if my knife was sharp enough slice paper, and just do what I needed to do cutting wise, that was good enough. Most mornings I give my knife a few strokes on the bottom of the coffee mug at breakfast, and then I'm off on my day's activities.
