- Dec 11, 2000
That sounds like the American version of what in England is known as “Knife collector’s alopecia”.Hairless patches on the arm - used to be called knife fighter's mange!![]()
Sharpness is a measure of the radius at the apex, ideally around .4 of a micron, when it gets to over 1 micron it starts to feel dull.
Keenness is measure of how polished an edge is.
You can’t get something sharper by using finer grit stones, only keener.
There are two types of cutting, slice cutting and push cutting.
Slice cutting requires a coarser finish and push cutting requires a finer finish.
The coarser the finish, the longer it will hold an edge. Microscopically, there’s just more edge to wear, micro serrations.
For most cutting tasks you don’t need any finer than 600 grit (American) or 1000 grit Japanese.
Most makers don’t do enough to remove the burr after sharpening. Stropping is essential.
Hoss
3 micron diamond spray on a paddle strop for most things.I'm pretty happy with my edges, I've been told numerous times that mine are Too Sharp.
But, for wanting to always improve....
I'll admit I don't feel successful with stropping.
Ok with wood, but leather has not been great.
What I do is use a Scott Gossman sharpening steel. I love this thing.
I wish it was bigger. I might ask him, or send out for treatment a Bigger piece of steel, for a bench top version? It a little bit more aggressive than regular stropping.
However....I have this piece of large balsa. I could try stropping again. What kind (brands) of rouge/abrasives do you use and can recommend? Thanks.View attachment 3086901View attachment 3086902
Get yourself a pocket microscope, you can see the burr , some are very small. They reflect light.Any suggestions on where to learn to strop better? I don't really know what I'm doing, and have been using a leather belt on a 1x30 without really knowing what angle to hold the blade at. It would be nice to know what to work on and what I should be doing.
Telephone book, you may want to save that book, in a few years it will be an antique. They stopped making them here around 2010.lolI make sure there's no burr, and I test using telephone book paper.
I am right there with you. As a small batch maker, I take my time on sharpening and enjoy the process. It's what got me into making knives. I always use bench stones with a guided system, and only inentionally raise a burr on the first stone. Every stone after the coarse grit is always edge leading, with a descending number of passes (ie 10 on the right then 10 on the left. 9 on the right 9 on the left....down to 1 pass per side for 20 times).I do feel what really makes a difference for a keen edge that the user will notice compared to other knives is a hand sharpening. I suspect makers knives that have burr issues were more likely sharpened on a grinder.
With hand sharpening, bench stones or guided systems, I have not seen burrs being an issue. I rarely and barely strop but have no burr issue when hand sharpening.
