richardallen said:
I'd say while an edge with a polished, 5° included angle is plenty sharp, I'd rather not use it for chopping hardwoods.
I would want about 30 included at the very edge (last 1/16") for chopping hardwoods, depends on the steel and the exact type of wood (knotty vs clear mainly) but somewhere in that area. But I was speaking of sharpness, or condition of the edge and not its gross geometry. Wood tools for push cutting, are kept very sharp and at those high sharpness levels stay cut better for longer, see Elliotts work on planer blades for example. The angle they need to be sharpened is adjusted to give the necessary strength, but this is a different matter than sharpness, Elliott quantifies both in detail.
Splitting tools such as mauls are usually not kept extremely sharp, not because it is a detriment, but just because the majority of the cutting ability comes from the raw impact power and the wood isn't actually cut as much as the grain is torn/burst apart so there isn't the same level of advantage to having a really sharp edge. You can see a benefit to initial entry on a GB maul vs a hardware store maul, as you can shave with the GB maul as you can with all thier axes, but the first time you miss the wood, or cut through it and hit the ground, both edges will have the same level of sharpness, essentially none.
http://i7.photobucket.com/albums/y269/CliffStamp/fiskars/hatchet/fiskars_gb_wood.jpg
There is a shot of a small pile of wood cut, two hatchets. Before the cutting the edges are raised to the ability to push cut newsprint on a 90, this is above shaving. They can maintain this edge through a cycle of 250-500 chops and still have the ability to do fine work, including cutting the paper, the Bruks lasts longer, the Fiskars is significant softer. I do the same with the Ang Khola's I have, I just have not used them in awhile. Essentially when you make an edge sharper you are cleaning it of debris, weakened steel and aligning it in a crisp centered path, obviously this makes it stronger and more durable as well as making it cut better.
http://i7.photobucket.com/albums/y269/CliffStamp/fiskars/hatchet/fiskars_log.jpg
It also reduces tendancy to glance, and even increases corrosion resistance. Of course there is the tradeoff of time of sharpening. If it takes you a half an hour to make a small improvement then this probably isn't work the time as you could cut a lot of wood in that period. But with proper use of abrasive grits and micro-bevels, sharpening should be minutes anyway.
-Cliff
