Sounds good but still explains nothing.
Remember what subforum you're in, man?:thumbup:
If your not satisfied with any particular edge then you continue to refine that edge until you are.
Rick,And just to let you know how stupid I get.... my final strop is done on 60,000 grit lapping paper...
Rick
Rick,
I am not familiar with lapping paper. How thick and stiff is it? And do you back it with anything?
Thanks,
Donavon
That is not true at all. Infact it is quite the opposite. If your knife edge becomes weaker with fine polishing, you are not sharpening correctly. Folk's first mistake is thinking they need to alter geometry to get razor sharp. When they work at a hair popping edge, they unknowingly lower the angle or they do not remove the wire edge completely.
You have to understand what is happenning as you sharpen. Things are happening at a scale that the human eye cannot pick up. You have to go by feel and more importantly... know what to feel for.
If you are serious (and perhaps a little obsessed) about sharpening. I recommend getting a jeweler's loupe... Then you'll be able to see what's really going on.
Rick
IMHO this statement being true or not depends on the grade of steel, temper, and the material being worked upon.
For example, I put a CRKT Crawford Casper folder that I believe is Aus6 to a 200 grit diamond stone using a single bevel at approx 25 degrees. It cut through a pressed-paper skid corner (the type that are commonly used under a layer of shrinkwrap at all four corners) using an aggressive swing. It made the cut and appeared no worse for the wear, cut through a few pieces of cardboard afterward with no hesitation. Honed the same knife down to 12,000 grit at a 35 degree bevel and performed the same test. The edge didn't fold, but a piece of the edge about 2mm long broke off to a depth of about 1/2mm where it made contact (it did complete the cut)..
Performed the same test with the same edge bevels and grinds on a Kershaw Salvo using 14C28N Sandvik, a Benchmade 722 with 154cm steel, and a CS Voyager with VG1. All passed wth no damage to the edge.
This also mirrors my experience with tools I've used to clear the vines on the more overrun parts of my property... all my cutters last longer with a coarse grind.
I'm curious as to why you felt the need to change the bevel angle to 35 degrees.... and why you would compare the two cuts? The 35 deg bevel would most certainly need more pressure to perform the same cut.
I will have to take your word for it that...the knives were properly heat treated.....
... but it does not add up, to me. What type of material was backing the skid corners when you performed the cuts?
Also, when you say angles of 25 & 35 degrees..... do you mean inclusive or per side? I just need to be sure we are on the same page, here.
Yes and yes. All knives were tested in the same manner.Same test? at 25 degrees or 35 degrees?... polished or toothy?
Can you explain your method for sharpening to a fine polished edge?
I recently purchased a Diafold Coarse/Fine sharpener and am very happy with it. I am now able to put edges on my Moras in the field that will shave the hair on my forearms. Diafold also sells an Extra Fine/Extra Extra Fine sharpener. I'm tempted to go to the next level, but how practical is it really? I might be able to show off to my friends, but does it really add much to the function of a user woods knife? How sharp is sharp enough? Does an "extra extra fine" edge last? Or will I be back to where I am now after just a few cuts?
A well written and thought provoking post, HeavyHanded..... thank you for taking the time to answer my questions.:thumbup:
