- Feb 22, 2009
My BM Presidio came from the factory pretty sharp. Sharp enough to shave arm or leg hair, but I knew that it could be sharper.
So I first used an Extra-Fine DMT sharpener to try to smooth out the factory grind lines. The diamond grit made short work of the 440C and another level of sharpness was reached.
For the next step, I used Dan's Arkansas translucent stone (which seemed barely more abrasive than marble) with a little mineral oil and polished the edge a little more.
For the acid test-a wet shave. Yes it worked, but I can tell it was still a bit rough and there's no way it's practical to shave this way. That's why I have a gillette fusion.
But, I always wanted to try it, and yes it can be done, a hollow ground blade makes it a little easier. Not sure which companies send their knives out wicked sharp, but Benchmades seem to have a good, but not great factory edge.
