I get mine hair shaving sharp to a point where it'll slice TP.
Then I add a microbevel atleast 15* higher than the main bevel, which leaves it hair shaving sharp (won't slice tp anymore...) but lasts forever and is very easy to maintain, three passes on each side with a ceramic rod or on the edgepro and it's back to shaving hair again.
I 100% believe that a sharp knife is safer than a dull knife...I've seen this first hand at work, my boss believes that sharp knives are dangerous...yet he uses ungodly amounts of pressure to cut something with his butter knife and always ends up pushing the knife off into his thumb or leg or something near by...'
I can't seem to get him in the mentality that a sharper knife uses less pressure to make the same cut.
Hair whittling sharp. Meaning you can shave multiple curls from a single free hanging hair without cutting the hair all the way through.
The steel is 1095. I did a very (and I mean very quick) reprofile with sandpaper over a dense rubber pad. Set the bevel at 400, then 600, then a minute or two per side on 1000 grit. Then hit it with my loaded strop (crap leather, home made, with harbor freight buffing compound.....only cost me about $6 total to make, including the compound). These are the first knives I have ever even used 1000 grit paper on before moving on to the strop. Normally I just go from 400 or 600 grit straight to the strop.
You can just see the hair sitting in between the two knives in this pic. It has already been whittled to make the curls.......but they are so small you can't see them until I get the camera up close and change the setting to macro.
There are those who say that this level of maintenance is too much work. That edge has not been sharpened on paper for quite a while. I just hit the edge with a few light passes per side on my strop at night after using it. Literally a few passes per side, and it is that sharp every day.
I keep the spey blades on those knives at shaving sharp, but not hair whittling. The edges on the spay blades are pretty much at factory angle, and pretty robust (probably like 25-30 degrees per side?). This gives me one hair whittling, and one hair popping (as it it will jump the hairs off the arm, but won't quite whittle hair).
I find that some of the simpler steels are just so easy to maintain at this level of sharpness with basically no effort at all (5160, 1095, 1075, etc).
Handing one of these blades to a non knife person is not always the brightest thing to do, however. You can warn them, but they just don't understand what a sharp knife means.
Now, the edges on these (even the hair whittling edges) are not what a true edge nut would consider refined at all. Under magnification they look terrible. There are about 10 levels of polish above what I am doing with my home made strop, and my cheap harbor freight buffing compound. It is green stuff, so probably cromium oxide? But, I guarantee, no where near the micron size of the better stuff that you get from sharpening sources.
I bet I could get it so much sharper, without much more effort with a better strop, and quality compound in smaller micron size, but I am lazy.
These are convexed by you or factory convexed, if so how long did it take you to convex the edge on the sandpaper, I plan to convex a new knife I just bought, it came with a v grind of course, I'm going to use the sandpaper over mouse pad method and then hit it with the green strop.
You have some sharp knifes Bigfattyt!
I used on mines a lansky system with the ceramic hones and the super saphire hone.
How sharp should I be able to get my knifes with this system?
Should I buy/make a strop?
when you cut something with ANY knife, you should see small sparks caused by the atomic fission induced as the sub-micron honed blade splits the atoms of what you are cutting..
of course, when using a properly sharpened knife, it is recommended that you wear a lead vest and lead crotch protector (this prevents your children from being squid babies)
Sharp as all hell works for me. I usually go with that, but not 'so-sharp-even-god-is-afraid-of-cutting-himself' sharp or even 'scary sharp'. Those take way too much focus for someone with as short an attention span as I have.
