gadegetgeek's advice is excellent. Whatever medium you decide on (stone, sandpaper, whatever), I would add that on a knife like this with such an odd grind I'd break the edge down into section when sharpening. Check out the pic below. Treat the area with the red dots as one section, the green dots as another section, and the yellow dots as a third section. Focus on each part of the edge (on both sides) individually, instead of trying to sharpen the whole edge at once. The only part of this blade that's going to be problematic is the little transitional area between the red and green sections. I would worry too much about that part of the edge, at least at first.
Those bottom two are a Japanese pattern called a Yori, Yori, a Dig, Dig! Quite fuctional really!^ this is excellent advice.
Original Poster certainly picked an extremely hard blade to start learning sharpening on. I highly recommend he follows G Scott’s advice and treats the blade as 3 separate sections.
Another suggestion is to watch youtube videos on sharpening.
Btw the reason people are saying this knife is not great quality is because it is a design produced by many lower end makers. It is actually supposed to be a “clone” of the popular Tom Brown Tracker knife with enough differances that one cannot call it a direct copy. However if you look at the edge shape we can see the similarity.
Every thread needs some humour. How about the Tops Tom Brown Digger Dagger?
Something tells me this may be better.
You’re most likely correct on that! ?? It’s a Dig Dig!I thought it was Hori Hori, although many Japanese words have various pronunciations. Yeah I would pick one up if I was a gardener.
Ok. Would is be best to use a stone or should I go for something like this?
https://www.sharpensbest.com/product-page/sharpens-best-long-handle-pocket-sized-knife-sharp
