Brian Jones said:
That's why reviews are always subjective.
The word subjective has two basic definations, the first is "in the mind" meaning it only exists mentally and not physically, imagined. The second is that it only exists for the individual. Some parts of a knife review are subject to the user, handle ergonomics for example. However since all people have similar hands (for the most part), there are general rules which if you break will find a lot of people making the same complaints so it starts not being subjective anymore, sharp edges and so forth.
If you are vastly abnormal, then your comments are more and more subjective. I know people with severe physical deformities in the hands and thus you can't apply thieir comments about ergonomics and security to the population as a whole. But of course you can for average people, there is in fact a whole branch of science devoted to exactly this, the design of ergonomic tools and equipment, there is even a lab for it at Mun, so no, you can't dismiss it as subjective.
Read "The axe book" for example which has various chapters devoted to every aspect of what makes an axe work and is in no way subjective, talking about such things as the precision and accuracy effected by handle curvature and head alignment, then going into detail about the head should be ground for the various types of wood and how to adjust this based on feedback. You can for example take an axe with a slightly offset head and any experienced axeman would know from a glance that while it would "work" it would not do so optimally, not a subjective issue. There are some of course like head weight, the stronger you are the heavier head tends to be ran.
This knife worked for me.
I could take any cheap hardware store axe, and without even sharpening it cut down and limb out a truckload of wood, buck it to lengths, and split it. However while it would certainly work, it would not do so very well, it would be outperformed many to one by various higher quality axes, Iltis makes a decent moderate/hardwood axes now specifically.
Just like while the Brute would also cut and chop pretty much anything, it will be vastly outperformed by several other designs because of basic physical laws, this is irregardless of the person using them. Of course users will have refinement, such as how far you can push on edge geometry, different people will have different tolerances based on skill and physical strength. You make the feedback meaningful by defining the terms using baselines.
Thus for example if somone notes they they think the Spyderco Paramilitary is their standard for a quality cutting blade you can judge their opinon of sub and above average grades. The more details they give the more meaningful it gets. Check Mike Swaims posts on rec.knives about a dozen years back to see how it should be done.
But yes it [Brute] will work, in the sense that if you put enough effort behind it you will get the job done, the same can be said of any knife of course on just about any job if you have enough skill and time. I can cut down a tree with a fillet knife if was so inclined, it will work in that sense.
I haven't found a cinderblock in ...
No rocks there either? Must be nice :
http://photobucket.com/albums/y269/CliffStamp/Heafner%20Bowie/?action=view¤t=hb_rocks.jpg
Of course why you are using blades which such over built edge geometries when you never hit inclusions is problematic. With this restricted scope of work a more optimal edge profile would be vastly slimmer, allowing a much higher level of cutting ability, many to one.
And again this would not be in any way subjective, any two people would note the difference in cutting ability and the potential for a gain is very large on the Brute give the amount of steel which could be removed.
Ask someone like Ray Kirk to make you a pure wood cutting blade and try it out some time to see just what can be achieved.
-Cliff
