- Mar 6, 2008
I buffed mine with a circular cloth setup on my dremel kit. It made it scary smooth, along with some olive oil in the pivot. All I have to do is tap the flipper.
i still we make a pics required tear down sticky with all the models![]()
I'm pretty sure olive oil will go rancid eventually.
Spinning Pivot Syndrome (SPS) is when the back side of the pivot turns when you try to remove the pivot screw. There are 3 common ways to cure it: 1: Heat the back of the pivot with a soldering iron to free up the Loctite, 2: remove the clip and put a piece of rubber band under the clip and re-attach it (the rubber band held firmly over the back of the pivot usually gives enough grip to let you loosen the pivot screw), or 3: take a dish towel or similar and press the blade into it while turning the pivot screw (the application of pressure on the blade usually applies enough torque to the pivot to allow you to loosen the screw). When I took the Shallots apart, I used method 3. Worked like a charm!
I've never tried the soldering iron trick, but several here have done it with success.
There are 3 common ways to cure it...
