I followed your advice on M4 and I have no problem cutting it. I had always heard that ceramic belts wanted high pressure and high speed. I think that is true for some types of grinding but as knife makers much of what we do uses the initial edge of the grit. When cutting unhardened steel maybe that doesn't apply as much but once you get into very hard to grind steels they cut so much better with a slow belt and a fair bit of pressure. I thinned the blade on my M4 pocket knife and it was pulling so many shavings off with a 220 ceramic belt that I am now wondering how hard it is. I also tested it on some M4 that
@Willie71 ran at 66Rc for me and it worked the same. I wish I could get back all of those 110 belts I used on his 66Rc Cru-Wear that I only got a few passes before they were gone. Thanks for the tip bud. Now if I could find a good 400 grit ceramic belt I would be doing awesome.
For most knives I use a sheet metal gauge. Once I am down to the thinest slot about 0.007 before I switch to finish grinding. For me that's also a great place to convex from. I have a leather platen that I really like for finish grinding. I either need to get a new flat platen arm or I find it best to batch up and do all the soft platen work.
