How to assemble a Spyderco Endura
91bravo
I got my teal s30v Endura in today and not really fond of the color of the handles. I picked up some red trainer scales and I'm going to put these on instead. I figured I would do a write up with pictures, on how I easily and successfully disassemble/assemble one. This process works exactly the same for the Delica as well.
I like to keep the knife upside down for this process. Remove all screws from this side of the knife.
Remove scale
Depress the lockbar, push out the pivot from the top, and pull the blade/washers straight out.
Once the blade is out, continue to disassemble the knife. I like to keep all screws with matching barrels, in their appropriate locations, hence laid out the way it is.
Doner scales and hardware.
Assemble everything as shown in the pic below.
A drop of Tuf Glide
Reinstall the backspacer spring and put a drop of Tuf glide on the washer.
Now reinstall the liner and scale. Loosely install the pivot and body screws. Here's where I lok tite the pivot screw and adjust blade tension. Check for blade centering and tighten the body screws. I forgot to take a picture of this step.
The knife is now assembled, centered and blade tension adjusted, just with no lock bar. Keep knife open, line up lockbar and push the barrel through until it touches lockbar.
With blade open, using both thumbs, push the lockbar in. At the same time, prop the barrel on something at the bottom that will push it up, once you line up the holes of the scale and lockbar. Looking down the hole and pressing down on the lockbar, will help line up the holes easier as well.
Once the holes are lined up, the barrel will just pop right in!
Lok tite the lockbar screw in and voila! You're done!
I hope this will help future Endura/Delica owners down the road, who want to tinker with their knives. Remember, the lockbar is the last thing installed, when you're assembling an Endura/Delica!
Great looking knife and awesome tutorial! Best I’ve seen online. :thumbsup:
It took me a long time to figure out how to reassemble them when I put these together...
I couldn’t find anything as informative as your guide. :)
Great post OP! Hopefully this can help people out who don't have experience with these knives. I remember trying to figure out how to put together a delica years ago. Took me longer than I'd like to admit to figure it out.
The first time I disassembled a Delica when they went to screw construction, I was giving myself fits trying to put it back together! I've done a whole bunch since then. Hopefully this will help anyone taking apart one for their first time.
The last step of getting that damn barrel in can be tricky sometimes. The advice of propping it on something while you drop the knife down onto it is very good, as you'll usually need two hands on the lock bar to get it perfectly aligned. Great tutorial!
Who made those scales? They look great!
You saved my thumbs! I was having a hard time replacing the screws, and this put me on the right track. Thank you, thank you!
It goes without saying that you void yoour warranty on the knife when you disassemble it.
Someone new to Spyderco might not know that and it should be noted.
From Spyderco website:
✓ Spyderco’s knives are assembled to exacting tolerances by trained technicians, so we discourage end users from disassembling or adjusting our knives. If a knife has been disassembled and reassembled correctly—so as to maintain its proper mechanical function—this warranty remains in full effect. However, if a knife has been disassembled and reassembled in such a way that, in Spyderco’s sole determination, the proper mechanical function of the knife has been compromised, it is no longer covered by warranty.
I always thought if you took it apart that the warranty was void. From the above that does not seem to be the case. Thanks!
I always liked CRK because they actually recommend the user's disassemble their knives and maintained them. I never felt that Spyderco had the same approach.
You'll have to practice some common sense and know your limitations when it comes to disassembling Spydercos. It's not rocket science as you can see in the pictures above. My thread was to help those that wanted to change their scales out on their Endura or Delica or Endela. They are all pretty similar.
It is a great post and did not want to detract from it with my comments.
I want to try to disassemble a Delica and it will come in very handy!
