I believe the Brownells stuff is the same as PBC anti-scale compound, which I have and it works
very well if properly applied. The only things I'm not the most fond of when using it are that you have to pre-heat the blade to ~500-600 (to get it to stick to the blade) and then you quickly sprinkle the powder on, which can be a bit messy and you have to pour a good bit to make sure every spot of the blade is covered. Of course you do this over a steel pan or backing sheet or something similar in order to not waste the all excess powder. It's not hard to do, but it may seem like an extra step/annoyance to some guys if they do it with every blade, but definitely not for one here and there. You definitely need to boil it off in order to get it all off and also scrub it a bit.
I just use a scrap of aluminum which a sharp edge and scrape off as much excess as possible before boiling, I do the same with clay hardened blades but don't really need to boil those. The aluminum won't leave any create any deep scratches like something like mild steel would.
Anyway, for years now (been slackin') I've been meaning to try some of the liquid anti-scale compound also by Bownells, the ATP-641 stuff that can be applied at room temp by simply brushing it on.
https://www.brownells.com/gunsmith-...ating-sku100002607-23076-49084.aspx?rrec=true
Apparently it crumbles upon cooling and will wash off in under hot water, so it might be a good idea to put a screen in your quench tank to filter out any of the coating that falls off in the oil. Also, I'm not sure about the drying time needed before heating it up in the forge. I'm sure some of the guys here have used it and know more about it than myself.
~Paul
My Youtube Channel
... (Just some older videos of some knives I've made in the past)
