- Nov 9, 2009
So beyond the peanut galley comments, SS won't blacken well if heat treated or chemically treated ?
Would it not be much simpler to just buy a black clip?
Take a look, I posted this a while back. And again, no I don't work for 'em.I've carried thing every day since then, the finish is about the same toughness level as parkerizing. Of course, it's also easy to reapply.
http://www.bladeforums.com/forums/showthread.php/850223-Caswell-Stainless-Steel-Blackening-Gel
Dip it in Plasti-dip.
Here, I just did another one so it could be seen on a polished stainless surface instead of bead blasted---pulled out an old favorite Spyderco.
The stuff has the consistency of Vaseline, so it's very easy to control and isn't spilling on stuff while you're working. The picture you see of the clip and screws covered in the stuff was taken immediately after I finished applying and then went and washed the acid off my hands--it turned dark grey while I was rubbing it on with a Q-tip and black during the 45 seconds I was getting the camera. Once I'd taken the shots, I washed the stuff in baking soda/water and water to neutralize the acid, washed again in plain water (keep an eye on those tiny screws) and then coated with mineral oil. In the morning, the reaction will have stabilized and the mineral oil can be cleaned off.
Do NOT use this stuff as though it were phosphoric acid and leave it on the steel for hours at a time. It is HIGHLY corrosive and is setting to work immediately. Five minutes after application, you need to be in the process of neutralizing it.
Surface prep was again a rub-down with 0000 steel wool and wash with mineral spirits. There are a couple of lighter spots on it---if you want consistent black you need to heat the pieces up to about 150 to 175 degrees before application, and doing clips you'll have to move fast because it'll lose that heat fast. I've been happy enough with my "charcoal" color results to not put the effort into heating them. It DOES work, though.
If you like, I can actually pull out the light box when I get home from work tomorrow and show you what the final finish looks like. If you've seen all you need to see then I'll save the effort.![]()
