Are you thinking just your sample was not hardened properly, or do you think it might be a CR wide problem?
I dislike the stock angles now and want to go more acute but dont know what I can get away with safely and still get a workable stable edge.
and have you tried any Strider s30Vblades?
Cliff, maybe hardheart and I can persuade you to look into this some more sometime
For me the "leap" from getting maybe 2.5" sharpness into the 3"+ range and even 4" with a couple of knives was all in using an incredibly light touch; I use ceramic rod sharpeners but I suspect the same principle applies regardless of method, and probably easier with an Edgepro because of the larger contact area.
I would describe the difference as almost shocking it's so subtle, just 3-4 feather-light passes is often all it takes. At first I thought this was so minimal that something wasn't right, so little extra metal would be removed after all .... and I really wondered if such an edge was any good in terms of retention, but you do see the benefits of high initial sharpness like that even after a fair amount of use.
Same here, I started examining blades under magnification a while back and it's invaluable. Eliminates most the guesswork when it comes to sharpening and trying to resolve edge retention problems.Using light pressure and using a lighted microscope to track the burr really helped me to improve my sharpening results.
Another thing I noticed was that with the Spyderco benchstones instead of the Sharpmaker rods it is easier to avoid burring, as the contact area is much larger. I lean the benchstones and the strop against the sharpmaker rods to maintain my angle for my microbevel because I still like using an angle guide, as I am relatively new to sharpening and especially freehanding on benchstones. Although, I don't bother with angle guides anymore when I'm just thinning out knives on my X coarse DMT benchstone, as that angle is only for shaping, and not sharpening, anyway.
BTW those are really exceptional sharpness numbers. You should send one of your best blades to Cliff, maybe you'll take over first place on his sharpness list from Ben Dale.Of course I wouldn't be surprised if Ben decided to answer the challenge.
