...Lastly I drill a 1/8" hole in one end and attached a paracord loop.
Why grind off the teeth from the blade piece? You can always flatten the back/spine to give yourself a good scraping area. Then you've got some teeth that can be used to scrape off magnesium shavings, as a hyper-aggressive firesteel scraper if needed, and as an emergency blade/saw to make a small knife out of. Depending on storage, it's quite unlikely to scrape into anything enough to have to worry about it.
Yeah, I just couldn't get a good spark consistently with the other end of the hacksaw blade. Is there a trick to the trade that I'm missing?
Ditto what he said about eating up your rod. Have you flattened off the spine of the piece? It's unlikely to give you good sparks unless you've got a good, crisp edge to scrape it with. Just take a file and grind it flat on that side.
