** Don't do this untill some more experienced forum-ites chime in.  I am an AMATURE! **
Here is how I fixed a blade with a similar problem:
In figure 1, you have a rounded tip.  In my case, it was a chipped tip.
In figure 2, I have scribed an arc along the blade that issolates the deformed part of the blade.  The arc should have a large enough radius to "blend" the new edge with the rest of the blade.
To achive figure three, I used a 6" coarse DMT bench stone with the blade perpindicular to the stone.  Initially, I worked the blade side to side across the  length of the stone.  As it started to near the final desired shape, I moved down to a fine diamond DMT stone and worked the blade for and aft with a slight rocking motion.
Once the blade looks like figure three, move to the edge pro and put your edge profile back on.  I did not attempt to restore any of the edge free hand.  I used the entire range of Apex stone.
End result is figure 4!
Once again, don't do this until there is some more opinion offered.  I might be instructing you on how to TRASH your blade!
