how to forge a nessmuk?
hey all, im tackling more forging projects primarily forging only for a bit till i can get a blade shaped pretty much as i want it to look, and i really love the nessmuk shape and would like to make the design a staple soon, only problem i have is newb that i am i cannot figure out exactly how to forge one out, as in dale chudzinski's version i think agrees with me most. i love that sine wave profile. could a few of ya chime in with a basic step by step? much obliged!
Hello! have you ever swung a hammer on hot steel? Prehaps you should work on your hammer strikes. Glancing blows move metal in the direction of the blow. Pretty much the "standard" Nessmuk shape is an upside down, drop point recurve, with an exagerrated belly. So to start,
1) Assuming we're workin round stock, heat the stock to a bright red. NO HIGHER!
2) Then use your heavy crosspien,(2-1/2 - 3lb) using the wedge side, strike the steel rapidly beggining about 3-4" from the bottom moving progressivly to the bottom. Flip over and repeat this untill you get to about 1/4" thick.
3) The shape will start to get a bannana shape to it, a little is ok, but if it starts getting too much, flip it so the arc is vertical and gently hammer it back to flat.
4) Once you have 4-5" of 1/4" flat stock to play with, shape the point then cut the bar so you have about an 3/4" long piece of round left attached to the flat. this will be the tang (Assuming you want a stick tang)
5) Square the 3/4" long round and begin drawing it into a long rat tail. once long enough flatten.
6) Back to the blade, to draw the exagerrated belly out a few simple glancing blows in the proper direction from the regular side of the crosspien will move the metal into place.
7) Bevels decide where you want the bevels and move to the front of your anvil, up by the horne you'll notice a small step, orient the knife so the edge of the step is directly underneith where you want your plunge. Now raise the spine about 1/2" off the anvil, but the edge still in contact and give it a good whack, and give it several whacks all the way out to the point. repeat lowering the 1/2" to 3/8" then the 3/8" to 1/4" so as to raise the plunge to about 3/4 up the blade, flip the blade and do the other side. after you finish give it a few straighting tweaks, normalize 3x each with a progressivly lower temp first to 50-75ºF above critical, then at critical, then 50-75ºF before critical, now let slow cool in the forge or in vermiculite to spheroidize anneal.
may not be perfect, your results may differ, but it's how I do it.
Jason
7) Bevels decide where you want the bevels and move to the front of your anvil, up by the horne you'll notice a small step, orient the knife so the edge of the step is directly underneith where you want your plunge. Now raise the spine about 1/2" off the anvil Jason
Outstanding summary!
I quoted the above section since this is something that is a step that is missed by many bladesmiths. Failure of this approach can damage your anvil AND makes geting the bevel even on both sides difficult.
Dean
thanks much, i have been doing some forging, but i cant always get it to move like i want yet. most of what i have is flat stock , but i do have some round, bout what size round stock would you use for a average sized knife?
5/8" - 1" is good all around size. I like 3/4" the best, the general rule is you double the inital diameter of the round by making it flat stock. (i.e. 3/4" round will come close to 1.5" flat, so on and so forth.) I usually use W1 since its easy to come by. and moves under the hammer a little easier than leaf springs.
Jason
