- Apr 3, 2001
No kidding.
I've been going back to basics with Christina Aguilera since '06, but thanks anyway.![]()
A’ight then. Enjoy your butter knives until you buy new ones.
No kidding.
Yeah. You’re not overdoing it at all.Took forever to get a burr on each side. It was after the fourth time of getting a burr on each side but no edge on the knife that I lost my temper and really went at it. This knife had the factory edge when I started. A full flat grind to the apex. I tried everything: micro-bevel, bevel, raising the bevel. I used a Sharpie throughout, and checked the edge with a loupe as I went along. The stone was brand new and cleaned after every sharpening. After the third sharpening, I stropped the edge, and it took a polish, which I didn't even want.
Whatever you like. Wine is very subjective, in terms of what people like or don't, so it's hard to make specific recommendations. At the time, I was a big fan of Australian shiraz - the Yellow Tail variety was very good and not expensive at all. Paired great with a peppered steak, BTW.What kind of wine?
Best to hone your knives when you're not pressured. I sharpen freehand and usually start with a coarse grit (220 DMT) if I need to set the bevel (an angle guide helps), then proceed to finer grits, usually no more than DMT red (600 grit). I find the DMT green (1200) grit great for a polished edge on high carbon steel wood carving tools, but high carbide volume powder steels like S30V and cousins cut better with a slightly coarser edge.
Unless there is something wrong with the heat treat or steel...it's probably down to a combination of technique and possibly either not creating a burr...or failing to properly remove it.
It takes time...but don't give up. It's worth learning.
I'd recommend using the bench stones to thin the bevel and reach the edge, (creating a burr),...and when you think you're just about there...finish on the Sharpmaker, (light alternate strokes), and see if it's sharp then.
I had the same struggles for a long time. I never got great edges until I used the Sharpie trick to draw on the bevel to see where I was actually grinding with the stone. Once you determine what angle you need to grind at to reach the tip of the bevel, grind that angle until you form a full length burr. Flip and repeat. Once you remove the burr after forming one on both sides your blade should be shaving sharp.
also if youve been going at it with the same stone for a while, maybe it needs to be cleaned off so it cuts the metal efficiently again
Freehand sharpening is all about feel, you got it from stropping! For me it was first polishing bevels by hand, practicing sharpening,then grinding on a platen that finally gave me that feel of flat.Take a breather for a few days. Fall back & regroup. Eat well and sleep well. Let it all percolate in your mind while doing so. But don't stress over it. The pieces will begin to fall into place if you allow yourself the time & the rest to let it happen. I'm pretty sure everyone goes through this learning curve in a similarly frustrating fashion. I know I did. It'll start to click, in time.
When I was learning, I spent a fair portion of the 'off-time' just stropping a blade on a paddle strop with green compound, while relaxing in an easy chair in front of the TV and sipping from a glass of wine after a good dinner. Just that simple routine of sort of casually, almost absent-mindedly stropping that blade managed to get my hands conditioned to the feel of the bevels in flush contact. Didn't realize how valuable that would be at the time. But I discovered later that my hands had 'learned' much of the touch for sharpening by doing this, even if my conscious mind still felt like I didn't know how to progress. It just happened, and that surprised me.
yee. the reflective spot is either dull (as in "rounded, not apexed") or it is macroburr. just by seeing reflections edge-up, one cannot tell for sure if it is macroburr or a non-apexed ("flat") spot.•Look at the knife edge-up under bright light. Any spots that reflect are dull.
What steel are you sharpening and what kind of stone are you using? What do you mean by raise the bevel?Thanks for the posts. I did use the Sharpie trick. And I stopped frequently to examine the edge under 8x magnification. The edge looked like a mess, even before I started, so I decided to raise the bevel. I got it to look clean and regular. Still wouldn't cut, though.
Buy new ones.
Gentlemen, the sharpening game has got me beat. I've spent a week trying to sharpen one knife, and all I have done is make it more dull. I've tried bench stones, the Sharpmaker, strops, ceramic rods. The whole situation is baffling to me. Extremely frustrating. I just can't figure this out.
Finish on the Sharpmaker? But that's cheating, isn't it?
Agree with the above. The SM is an effective tool. And using it after learning freehand on stones is making the best use of the tools available. Using the SM gets easier and works better with an acquired touch for freehand. That's the beauty and the epiphany of learning freehand sharpening - EVERYTHING works better after doing so, including all of the tools meant to make the process simpler for everyone.There is no cheating. Only getting a sharp knife, or not. I often do 99% of my sharpening freehand on my stones / plates...and finish with a few light passes on the Sharpmaker.
It's simple and effective. But it's only a suggestion. Do as you wish.
This statement is absolutely true! A sharp knife is a sharp knife, no matter what technique is used!There is no cheating. Only getting a sharp knife, or not. Do as you wish.
