- Apr 24, 2009
Hi, I just tried to make my first brass bolster for a puukko knife. In other words I needed to get a rectangular opening with exact dimensions. I first drilled a few holes with 2mm drill, than used thin round file to connect the drilled hole and then a small flat file to get a rectangular opening.
The problem is - the blade thickness at the ricasso where the bolster is supposed to sit is the same as the thickness of the tang (3.5mm with this blade). At first I had the width of the opening in the bolster OK, but until I got the other dimension right (so that the bolster could slide all the way down ) I inadvertently increased the opening also in the other direction. This resulted in a gap between the bolster (once in place) and the blade sides. It is just a fraction of a millimetre, but you can imagine how it looks.
My question is - how to solve this problem? Is there an easy way to keep the width of the slid in the bolster untouched while working the other direction, or should I file the thickness of the tang down a little so when I make a new bolster this gap does not show?
Thank you in advance.
