I had a heck of a time getting a good pic, but if you look at the spine of the blade close to the tang you can see the swedge is more pronounced there than it is farther down the blade. This was pretty and even once i finished at the grinder. I went to 100 grit on the grinder and then hand sand at 100 grit and heat treat. I then sand all the way up to 1000 grit. This uneven grind line happened during the hand sanding, probably trying to get that one stubborn scratch out.
Also, the lines aren't as crisp as i would like. I guess i need to sand to a higher grit on the machine? If i do, I'll still have to hand sand, so i will encounter the same problem? What grit should i sand to on the machine?
