I actually like the look of that also. It's almost like a black oxide coating, and in a way I guess it is. Did you take the knife apart to dip the blade?
I use Fluid Film on my Gayle Bradley and it is a perfect protectant. No patina and no rust. It is food safe as well.
Does it do a good job of lubing the pivot?
Sounds promising, but I wonder how it compares with a Marine Tuf Cloth. It more or less sounds like an oily wax, and that "will not dry out" sounds a little troubling like it would easily be wiped off or washed off.Yes indeed and it doesn't collect crud.
Unlike Tuf-Glide. Fine on blades, not so great as a lube IMHO.
Tri-Flow is a dry lube that is probably better than liquid lubrication agents for smoothing out blade action. Try it out, it's typically used for cyclists on their chains.
I like that on my flashlights, but I kind of get the feeling that it would roughen the opening if you have it in the pivot area.Cerakote?
An ideal solution would be to find someone to put a DLC coating on the blade. DLC + CPM-M4 = perfect knife
Ahhh, okay. DLC then. There are people who will DLC. I forgot about DLC, thanks.
Diamond-like carbon is relevant to my interests. Who does the dlc coatings?
It might cost a bit, but I think it would be wicked cool if you DLC/PVD coated it:
DLC - Diamond Like Carbon
PVD - Particle Vapor Deposition
DLC is better, but they each physically bind a protective layer into the metal.
Richter Precision
Contact info is on the site, can't hurt to give them a call, maybe they could do it for cheap (honestly, probably like $60USD for a custom service like that). You'll probably have to blunt the blade and then resharpen (obviously) when you get it back.
Well, in all honesty, I use Blue Lube to lube my knives. Great stuff.
Tri-Flow is an excellent lube as well. :thumbup:
