How to make wood handle knife tacky?
:D:thumbup:
OP, they make clear skateboard grip tape nowadays. It'd probably be way too aggressive in texture as is, but you could smooth it down a bit with another abrasive. It would allow the wood grain to show through fairly well too.
Piece of sandpaper would probably be cheaper though:D
Nitrocellulose will work but it is also susceptible to heat and rubs off fairly easily.
I've personally used this stuff on knife handles; huge difference in traction and is easy to work with:
I came across this while getting some sand papers at my local auto parts store - Plasti Dip Translucent Rubber coating. And I thought this is perfect for the OP's application.
What's good about the Plasti Dip is that it can be peeled off if you changed your mind down the road pretty easily and leaves no residue.
Andy will bead blast g10 to give it more grip, I believe. My Fiddleback's are pretty slippery, but they aren't wood.
It may be the leather worker in me, but I agree with the fellow above. Beeswax, used sparingly, would be my first choice on wood.
What about checkering the handle? It would be a shame to wrap a beautiful piece of wood in hockey tape or the like.
What's the current finish? It seems a shame to cover up that wood. If it's currently got a lacquer or other impermeable finish then I'd be inclined to remove that back to bare wood, then treat with Tung oil. Compared to Linseed this doesn't darken or yellow the wood so much, and gives a less glossy finish. Tung oil is also food safe, whereas boiled Linseed oil is poisonous (or rather the drier added to BLO is).
Tung oil is my preferred method also.
How to make it tacky? Cover it in skulls and painted-on dripping blood over a nice lime-green-and-burnt-orange color scheme with a faux-fur lanyard and a YOLO lanyard bead with "Turbo" etched on the blade.
Ohhhh, you meant the other tacky...
Hahaha you got me on that one, good one sir, one of the funniest comments ive seen on the forum. +1
I use Plasti Dip for a lot of tool handles including old pliers that have had their grips worn off. It dries out as a dull/matte version of the way Channellock brand pliers feel, and that was exactly what I wanted so it is perfect for what I need. It does add some thickness though so if it needs to fit a sheath that grips the handle, it might not be the best option. The coating could also rub off after continuous rubbing against the sheath. It does stick well to wood though.
For wood handles what I use is cheap Rustoleum lacquer. A couple of coats of it make the knife handles a little nicer looking too, while making it tacky to the touch. I did it to this "Old Hickhart" handle and it has turned out great. It is much more grippy; enough to convince me to not add the finger grooves I had considered adding to improve its grip. I can't recall if I added any stain but I doubt it. It really brought out the color in the wood though.
Below it is an as-is from factory butcher knife for comparison.
Note- I didn't let the lacquer dry quite enough, so when I put it back in its sheath the leather decided to stick to the lacquer and made the forward-half of the wood more dull. It looked horrible when I first saw it, but it made it even more grippy, so I'm not complaining!
S.Alexander's idea is great, checkering would add a good look to any wood handled knife, and not require any wait time after applying a finish. Just be careful though, I've heard of gun nuts, after buying a checkering tool, spending hours checkering random wooden objects just for the fun of it. :D I'd like to think I wouldn't do that, but then I don't have a checkering tool.. yet..
