- Jun 4, 2010
I reread this thread and now I want to ask: how light IS the pressure required on the 6k stone?? Or any other stone for that matter.
I'd like to know this estimate as well, I only what I use.
I've found if going even a bit too hard backhoning on waterstones with an acute angle the edge can literally sway over a bit - almost looks like a wire edge only more subtle.
On high RC steel it can fracture the last few microns right off the apex. I'd estimate I shoot for an ounce or less but is hard to say, even with a good digital scale the value jumps around and won't accurately read momentary shots less than an ounce or two.
Sometimes if I'm going from a coarse stone right to a polishing grade one I find I can use a bit of force - a couple of ounces for the first few passes as I'm working the high points down a bit. I suspect because the surface area is small, the contact pressure is even more amplified and those come down very quickly. Once I can see a bit of brighter finish along the edge I dial it way back.
I also believe the density and composition of the stone make a big difference - even very hard resin bonded stones will tolerate more force than a ceramic bonded/fired one before getting into trouble.
Edit to add:
I find once I get into brighter levels of polish my waterstone edges tend to reliably feel stickier than other means. In some cases not by a large margin and also tend to require more QC to really get the best.
The "stickiest" edges I have ever made came off of a clear maple strop loaded with Flexcut Gold and a few drops of mineral oil. Absolutely wicked catchy and would barely tug cutting the tops of a fingerprint whorl. Again, they took a lot of QC to reliably achieve and the boards are more prone to contamination than just about anything else you can imagine - not convenient but a great noodling exercise - also tolerated and actually worked best with a solid 6-8 ounces or more. The maple is more forgiving than a waterstone...
https://www.youtube.com/watch?v=gfblDsTy-FY
