how to take byrd cara cara apart?
Is it hard to take the byrd cara cara apart? could somone tell me how to get it apart, and is it hard to get back together?
The hard part would be to put it back together. Do you need to clean it or replace a part?
Also make sure you have the correct tools. I can't remember, but it's probably torx construction.
I took mine apart about a week ago, with no difficulties. Getting it back together was a different story. For some reason, the hole for the pivot in the liners didn't quite match up. After messing with it for over an hour, I ended up enlarging the hole in the right (from the back of the knife) liner with my dremel.
Probably not the best idea in the world, but it turned out fine, and if it hadn't, it's only a $20 knife.
i need to loctite the hex screw nearest to the lockback. can i just take it out, or will somthing fall out if i do. If guessing its just the pivotscrew for the lockback lever thing. it keeps getting loose so i gotta loctie it.
