If pin point RC accuracy is not a great factor, you can buy a set of testing files that will put you pretty close. With a little experience with them you can get a feel for the bite, or lack of, and get within a point or two. The set goes 45, 50, 55, 60, and 65 RC. If one bites, and the next one down doesn't, then you are somewhere in between. After using them a little, you get a feel of about where the hardness is by the amount of bite you get. It helps if you have a few testing blocks of a known hardness. Not the best way, but will get you by for any practical purpose, and a lot cheaper than a RC tester. If you knew someone with a tester and HT capability, you might get them to make a set by re-tempering regular files.
