Cougar Allen
Buccaneer (ret.)
- Oct 9, 1998
If you use a statistical calculator you can just type in your results and it calculates standard deviation for you. That's the easy way....
90.7 +/- 5.9nozh2002 said:
92.0 +/- 4.8
75.3 +/- 3.2
Most spread sheets do, you are looking for the standard deviation in the mean here. So take the standard deviation and divide it by the square root of the number of trials.nozh2002 said:I found that StarOffice spreadsheet has standard devastation.
I got an email about that recently. You can make a very similar setup yourself with a Ti-83+ and some force probes from Vernier for a few hundred dollars, probably a lot less if you got it all on ebay. This doesn't actually gain you any more information that the above setup except that it require less readings as it reduces some random influences. You would still want multiple readings along the blade as it is still a spot check. The CATRA setup has possibilities for a lot more than edge retention and sharpness though, you can examine cutting ability, wedging and so force as it actually generates a full force curve as the knife is pushed through a media.Ed Schempp said:The sharpness machine is a table top affair that sells for about $18,000.
Cliff Stamp said:So take the standard deviation and divide it by the square root of the number of trials.
When taking readings from analog devices you estimate the fraction inbetween the calibrated lines, so if it calibrated to 10's then you estimate to 1's. After taking your sample data you round according to the standard deviation in the mean.nozh2002 said:Now weight scale I use has scale by 10, so I should round it to 10 - one unit on scale.
